Variable turbo pics
![Cool](https://www.dieseltruckresource.com/forums/images/icons/icon6.gif)
I know, I know, it's on a second gen, but the 1st gen forum is my roots![guitarist](https://www.dieseltruckresource.com/forums/images/smilies/guitarist.gif)
Anyhoo, getting a little closer to having a running variable turbo on my 12 valve and thought I'd post some pics. Don't have a lot of pics, so some steps are missed, but you'll get the idea. I plan to regulate the vgt via drive pressure. Others have used this method with excellent results. Have the gate start moving at 40psi of drive pressure and boost and drive are about 1.25:1 up to 40psi
Will be using an electric solenoid to pull the housing to the smallest position for e-brake mode. Should have around 300 clams into the entire mess once completely functional. Enjoy the few pics I have![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
Drill and tap he351vgt turbine housing for pipe plugs. Thread in pipe plugs and cut them off with sawzall and smooth out.
![](http://i128.photobucket.com/albums/p191/sloc1443/t2.jpg)
Assuming you have access to a 2nd gen hx35 elbow, cut the oddball flange off the he351 housing's elbow and have a good welder (since it's cast) weld the oddball flange to your stock elbow. Now it'll bolt to a stock downpipe![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
![](http://i128.photobucket.com/albums/p191/sloc1443/t1.jpg)
Had to do some clearancing on my stock manifold and get creative with studs, but with the new pattern, it bolts up like it grew there.
![](http://i128.photobucket.com/albums/p191/sloc1443/t6.jpg)
![](http://i128.photobucket.com/albums/p191/sloc1443/t5.jpg)
![](http://i128.photobucket.com/albums/p191/sloc1443/t4.jpg)
Fresh head and repopped sticks and an he351vgt-a thing of beauty!
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
![](http://i128.photobucket.com/albums/p191/sloc1443/t3.jpg)
I'm in the middle (well kind of stalled on, since I swapped the Dakota to V8) of doing this on my dually. Thanks for the pics, I like the idea of putting the pipe plugs in and re-drilling the flange. I was on my second attempt of an adapter that put the charger in a spot I did not like. Thanks again.
Thanks for posting your turbo project. I've got one sitting on the bench until I figure out how to go about it - also kinda waiting on the crew since everything will get swapped over. There are adapters on fleabay if I can figure out which one to use! Have you got more detail shots of your set-up and/or links to how to do it? I got the stock 4", 45* exhaust elbow so I'll have to fab a downpipe.
I'll post up some more pics later today. Gotta tear it back down to fit the turbo drain anyway. In the case of a 1st gen downpipe, you'd still only have to get the oddball flange from the he351 welded to your stock downpipe.
Oh yeah, Pete....who invited him anyway?
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Hey Aaron, long time no talk
I'm gonna try and copy this:
http://www.youtube.com/watch?v=BnHGbN67PIM
Anyways i've got one of these in the parts shed that I was going to put on the D250. Which i'm now selling. So now i'm thinking i'll replace the HX40 with it.
But looking at that video it looks like he is using manifold pressure to open the vanes, how were you planning on using drive pressure?
Yeah, my bad on the video. There's a guy on comp-d that uses drive pressure through about 10' of copper line with a stainless filter. With enough afc tuning (on his p-pump) the turbo lights instantly and is about 1:1 by 38psi. He's got several thousand miles on it now with no complaints, so I'm gonna start there.
