What is the optimum RPM's when towing?
Old 06-06-2011 | 02:50 PM
  #31
CoastalDav's Avatar
When I had my 00 Dodge with the NV5600, towing the same trailer, it would always do better in 5th at a slower speed especially with the 3.55 gears. 55mph would show 13.5 on the instant fuel mileage thing in the overhead. That only told me the engine was not loaded as much with 235hp and 460 ftlbs of torque, anything helped. In Sixth at 63-65 the truck consistanly got 9.8 to 10 mpg. Needed some more rear to run in OD. Did not have an EGT reader in the truck then. I really think that 5.9 with a set of 4.10's would have done good with my trailer.
Dave
Old 06-06-2011 | 05:00 PM
  #32
Rednecktastic's Avatar
At highway speeds (they can vary) and depending on the load (uphill, wind, drag, weight; they can vary) between 1700 and 2400 rpms is where I keep it. If they vary from that I feel I'm doing something wrong.
Every scenario is different, different trailers, tires, wind, road, etc.
I don't go below 1700 rpms because a cummins mechanic told me not to , it's too close for comfort in the bog zone if I'm not paying attention.
I'm not passing 2400rpms unless it's a large grade and large load.... and I should probably slow down .
Old 06-07-2011 | 03:35 PM
  #33
nkennedy's Avatar
Loading the engine was my main concern, because it seemed the coolant ran a little hotter when the engine was turning higher RPM's in the lower gear.
Old 06-07-2011 | 11:02 PM
  #34
HOHN's Avatar
You can see this from time to time because the head flow gets significantly more restrictive at higher RPM. Sure, you're making boost pressure up in that range, but the FLOW isn't any higher. If you're loaded so heavily that you're nearly choked flow, I can see how higher RPM might increase EGT, even in 5th.
The elevated coolant temps are partly due to proportional increase in restriction at higher RPM.
JH
stanbnv
07-15-2010 09:36 PM
goose2w1
08-20-2007 08:04 AM
kawi600
05-20-2006 10:29 PM
durasmack
22
11-02-2005 05:14 PM
fishin fever
02-22-2004 08:32 PM
Quick Reply: What is the optimum RPM's when towing?
