Washing the RV??
Old 04-20-2004 | 08:47 PM
kandgo's Avatar
Washing the RV??
Got the water tasty and clean, now for the annual cleaning?? What do some of you use?? For the black streaks and black film?? Thanks,,,, Rick
Old 04-20-2004 | 09:46 PM
DPG's Avatar
DPG
I use a commercial black streak remover that I buy from my local RV supply. Spray on, scrub with a long-handled car wash brush. rinse real well with hose. Seems to work real well. After I get the exterior (wavy aluminium) clean, I use a a spray-and-wipe detail wax to bring back some shine.
Old 04-20-2004 | 09:58 PM
Tfeore's Avatar
I wash mine real good then use "ProtectAll" kinda of expensive ~ 30.00 gal takes me about a quart to do a 27TT, wavy aluminum. I up for suggestions also as the product works great but it is an all day process. Well at least several hours. It works though.
Old 04-21-2004 | 02:12 AM
Teddroe's Avatar
Just build ya a big ole pole barn and keep that sucker in there.
No black streaks in there.........
Old 04-21-2004 | 07:57 AM
FiverBob's Avatar
I'm with tfeoere - - I wash using a car wash solution. Then coat with ProtectAll. I spot clean any streaking with ProtectAll. Real quick and easy to use. You can also try the "clothespin on the gutter" trick - - it really helps keep the streaking down. I coat my unit probably about three times a year. Washes easier, has UV blocker, keeps it looking good. I even coat the windows. Water just beads up almost as good as RainX.
Old 04-21-2004 | 09:22 AM
kandgo's Avatar
Thanks, I moved to a new place two years ago and have not gotten around to building a cover for it and it really shows as this is a pain letting it set out all winter. I will try your suggestions, someone else here once suggested a product called simple green?? Never heard of it, the wife says wally world has it so I am going to try it also. Thanks again, Rick
Old 04-21-2004 | 09:40 AM
propinc's Avatar
Speed secret for the DTR people;
You will not believe how well "Awesome" works! actually it works on just about everything .... don't leave it on too long though or you will have some thinning paint. You can get it at just about any 99 cent store for 99 cents .. try it it will solve your problem quick and easy no more black streaks.
I got the tip from Ronda at Lance Camper years ago been using it ever since
Enjoy!
Old 04-21-2004 | 09:51 AM
kandgo's Avatar
Huh? I will go and try to find some, how long is too long?? Never heard of a 99c store, but that does not mean to much as I do not go to town often Ha Ha. Thanks,,,,Rick
Old 04-21-2004 | 12:22 PM
FiverBob's Avatar
You must remember, when using anything stronger than a mild car wash solution, you will remove all wax and coatings all ready on the unit. Not fun putting it all back on again.
If you have a decent coating on the coach, dirt and streaks will remove pretty easily. In fact, as previously mentioned, a little ProtectAll does wonders to removes the black streaks (if there are any that don't easily wash off) if the coach was previously protected. Stubborn stains can be quickly removed with Gel Gloss, a fibreglass polish - - this will even work on light scratches with some elbow grease.
Old 04-21-2004 | 01:17 PM
dctoner's Avatar
"Awsome" is a brand knock off of Simple Green(SG), SG is a strong cleaner, great degreaser, several shops that I know of use it in their parts washers.
Do not use it full strength except on stubborn areas. Make sure you rinse well. SG also works well to help rejuvinate dry rubber seals. A company I worked for used it to clean the rubber rollers in Laser Printers.
SG can be found just about any where, in fact I just saw it in Home depot yesterday.
http://www.simplegreen.com/
I have had good luck with SG, but I think Dawn dish soap works well also, and it's not as strong as SG
Just my .05
Old 04-21-2004 | 08:11 PM
jka's Avatar
jka
Trisodium Phosphate, comes in liquid or powder form. Available at Home Depot and found in the paint dept. It mixes with water and is very inexpensive, about five bucks. It's used for washing walls before painting, removes any grease, grime or oil. Sounds like it would be harsh but its not.
I have been using it on my aluminum TT for 2 years, leaves nothing behind but shine. Removes black streaks realy well and doesn't hurt the tires or rubber seals on the windows. A friend of mine has one of those ice cream shops shaped like a giant ice cream cone. It's made out of fiberglass and he has been using this stuff for 4 years to wash down the store. No fading or streaking.
Nothing like a clean shiny trailer!
Old 04-21-2004 | 09:20 PM
Tfeore's Avatar
"jka" thanks for the info, my wife has about 3 boxes left over from the last time I painted, if I get rid of the "TSP" maybe I won't have to paint Plus my rig looks great. Thanks again.
Tom
Old 04-21-2004 | 09:25 PM
AaronT's Avatar
I use an RV/Truck wash, then use 303 Aerospace Protectant. It works great on everything, provides UV protection and you just spray it on and wipe it off. Great for rubber seals on slide outs, tires, etc. Shines up the 5er just like new.
Old 04-22-2004 | 01:41 PM
Big dawg's Avatar
FiverBob,
Where do you get the Gel-Gloss from??? I need to also clean my 5er and I'm looking for some good stuff to remove the black streaks but I don't want to damage the fiberglass finish.
Big dawg
Old 04-23-2004 | 08:21 PM
jka's Avatar
jka
Glad it worked for ya Tom! It's great when you find something that works well and doesn't cost an arm and a leg.
Keep on camping.
Quick Reply: Washing the RV??
