Vibration While Towing
Ok, got a question for you guys. I have a stock '06 2500 (see signature) and a 20' Flatbed 14K lbs trailer. When I tow it with the Dodge, it has a nice vibration in the truck from about 55mph to 60mph. The truck does not vibrate at all when unloaded. The tires on the trailer look real good, have good tread and are 16" E load rated. I even got them balanced thinking that might be the problem. None of them look like they have cord seperation. I even took the front two tires off the trailer (its a tandem single wheel) and that did not help. I have 50psi in the trailer tires. I never noticed any vibration from the trailer towing it behind my Ford, but that had a little softer rear suspension. It vibrates un-loaded and loaded with about 3000lbs.
I am going to go to a friend of mines and hook up to his trailer to see if it does it with his trailer, indicating it would be the truck. I might eveen try and tow the trailer behind the Explorer to see if that vibrates while pulling it.
Any ideas? All the suspension looks good, and the trailer really hasn't been used much since new. This is the only load I have had on the truck since I have gotten it.
Thanks for any help,
Tobin
Tobin
It squats some, but I am talking about the trailer unloaded and with a very light load (~3000lbs). The trailer sits pretty level and the truck barely squats in the rear when I put the trailer on it.
Thanks,
Tobin
Thanks,
Tobin
Jacked up all tires on truck and trailer to 70 psi, still does it. Towed a friend trailer that is about comperable but 24' long, and no vibration. Friend of mine is going to tow my trailer with his truck and see how it does. Very annoying, I really don't want to have to get rid of the trailer if it just does it with my truck.
Tobin
Tobin
I'd say try towing the trailer with a different truck.
You may have a bent wheel, alignment issue, broken belt on a tire that isn't easy to see, or some other issue with the trailer.
Also, it hasn't been mentioned yet, but inspect your hitch closely, and check the related bolts and hardware.
Thanks for the ideas, I will give them all a look. I am going to tow the trailer with a buddies truck to see if still has the shake.
I would say it shakes the truck more than a vibration.
I gotta tow a buddies boat, I will see how it does with that, it is a decent size boat.
Thanks,
Tobin
Thanks,
Tobin
