Typical trailer tire wear?
I have a 2 axle 14k equipment trailer and have noticed for quite a while that most of the tires have ballooned out in the center of the tread, while the outside edges seem to be at reg level. It reminds you of a broken belt, but rather all way around the tire, and all tires have some level of this wear. They are not dry rotted, and are about 4 years old.
ANyone know what causes this? I have had enclosed trailers over the years, and never had any do that.
Our cattle trailer did that, and it was broken belts. They were a cheaper no-name tire. 1 had a blowout a while back, and the other 2 ended up with broken belts, so we replaced them all with Firestones, and have had no problem since. The tires are overloaded weight wise from time to time.
I would guess by the 14000 lb capacity of the trailer, you either have load range D or E tires on the trailer since you truck shares at least 1400-2000 lbs of the load.
If your not running a full load on the trailer all the time, and your running max inflation in the trailer tires, after four years I would expect them to have less tread in the middle or worse.
I don't really know what they look like, but, my dually rears use to wear out in the middle long before the outsides. Thats because I always had to much air in the tires. I now run 55 in the rears and that problem has gone away with this set of tires.
Dave
Dave
I noticed one of the tires on my 5th wheel looked like that, but it was a different brand than the others. I thought after this last trip of the season, I will replace it in the spring...
The tire had other plans, and exploded out on the highway...
Dave88LX
14
09-01-2011 11:36 AM
hoot
03-30-2011 08:32 PM
