Trailer light harness problem
I bought a 7 pin to 4 pin adapter. I plugged it in hooked up my trailer and the running lights don't work. Turn signals work brake lights work, but the running lights don't. Anyone have any ideas. I've tried messing with it some. I don't get it.
Test light it at the plug... No use going any further until you have done that... If you don't have power at the plug >> Then check the fuses... After that... Trace the wire for shorts... After that... Check the power distribution box that the fuses are in.
First you just have to see if you are getting power out of the plug.. (the 7 pin)
If you are >>> Check it out of the Flat 4.... Then trace that through the trailer to make sure the brown wire is getting a good connection at all of the lights and now shorted or cut anywhere... Look at all of the points where the wire contact the trailer and make sure that there is not any rubbed through spots...
I know it is a lot of work... but... thats how it goes...
OG
OG
OG
OG
Leon441
01-13-2005 06:49 PM
Mechanos
12-21-2004 08:56 AM
