Towing a car one way cross country?
Old 01-12-2004, 08:18 PM
  #46
Steve Roseman's Avatar
If you buy a trailer and plan on keeping it, make sure it's what you want. A trailer with 7k lb. axle rating will be able to haul between 5k and 6k lbs., depending on the weight of the trailer. I have a 16 footer w/7k axles, most of the time it works great but some times I wished I had spent the extra $700 and went with a 20 footer and 12k axles.
Unless I missed it, nobody mentioned driving the rear wheels of the truck up on blocks to ease the loading angle on the trailer.
By the way, that's a beautiful car!
Old 01-12-2004, 08:43 PM
  #47
handymantim's Avatar
Lightman,
Yep, the front tires have to be hitting the stops at the front of the trailer. It's been a while since I've rented one so I don't remember exactly how those stops are built. From what I can remember, you lay the straps on the trailer and drive over them and then wrap the straps up/around the back side of the tire and then feed it through a ratchet tie-down at the front of the trailer. If your front air dam is too low, maybe you could build/cut some wood to extend the stops under the air dam.
Steve has a great idea to drive the rear wheels of the truck on blocks.
I just drove past a Penske rental place and they had car haulers. You might want to give them a call too.
Good luck
CTDjeeperman
09-18-2008 07:30 AM
crossy
11-28-2007 05:37 PM
jj3500
08-06-2006 08:41 PM
PWT05Dodge
0
06-03-2006 12:36 PM
betsycam
08-09-2004 03:07 PM
Quick Reply: Towing a car one way cross country?
