Towing 11000lb @ 55mph
Old 02-02-2007 | 07:58 AM
crobtex's Avatar
Originally Posted by ib516
An Edge EZ would be my suggestion. I love mine. I tow about 9000# worth of RV. Mine's a 33' travel trailer, not a 5er.
With the EZ, I run in OD at about 65mph. Only downshifts on the bigger
hills.
I agree. The EZ ain't gonna make it a race truck, but it will help you with towing. With my 5 spd, it made getting up to highway speeds a whole lot eaiser.
Old 02-02-2007 | 08:23 AM
blackdiesel's Avatar
Registered
What about the smarty? it'll give you the power down low and a little more fuel up top. all around one of the best towing programmers/boxes out there IMO
Old 02-02-2007 | 08:29 AM
bnold's Avatar
Originally Posted by pwirch
I would venture to say you have 4.56 front and rear. If you have different gear rations in either end then you are going to blow up your transfer case.
I'd venture to say not... As long as he is not using 4x4 on dry concrete he should be fine. Most usually say to be safe make sure your difs are within 1-2% he is at 1.5% if the ratios he gives are correct... When you think of tire wear, air psi, etc 1.5% is not all that much
Old 02-02-2007 | 08:50 AM
Diesel Doc's Avatar
they don't make 4.56 for the dana 80, or didn't at the time. .07 difference is next to nothing, it's less than having worn tires on one end of the truckand new tires on the other. alot of trucks come with slightly mismatched gears from the factory (especially fords).
Old 02-02-2007 | 09:32 AM
TXTad's Avatar
Originally Posted by TNContractor
TXTad is an underdrive avail for an auto? If so I would love to have one for mine.
I've read about them on these forums. Search for Gear Vendors. There's also one from US Gear I think. I don't have one, but it seems the popular opinion is that one is better for an auto transmission, while the other brand works better for manual transmissions. It may be that people suggest the Gear Vendors unit for autos.
Tad
Old 02-02-2007 | 11:32 PM
TNContractor's Avatar
Looks like Gear Vendor is the best choice for an auto. Any idea how it would work with an e brake?
I guess I should start a new thread with that question.
Thanks for the info.
Old 02-03-2007 | 08:51 AM
wildwood2500's Avatar
I have 410s 35 tsl swampers and pull 2 trailers at the same time about 19,000 lb to pismo all the time, no problem running 60 to 70 mph. pull the hill comming out of pismo in 4th at 35 to 40mph 2,000. if i could post a video i pulled out a perterbilt that got stuck in the sand he went to turn around and got stuck.
Elohim1
04-04-2008 09:02 PM
NCFisherman
27
02-27-2008 09:14 AM
Mcc2430
02-10-2008 07:04 PM
john henry
07-13-2005 01:07 PM
fishermansteve
03-31-2003 09:29 AM
Quick Reply: Towing 11000lb @ 55mph
