Tire Ware
Tire Wear
I've had this happen on a few Dodges that I've owned, but when ever I pull the 5th wheel travel trailer, after around 1000 miles I can see the front tires have a noticable uneven wear. Its at that point they would need to be rotated to the back. I have messed with lowering the tire pressure and I think that helped. Does anyone have any other ideas to help with this problem? Thanks
All trucks and all tires vary, even if the same model/make. I take a large piece of builders chalk and put thick stripes across my tires with the load I want to adjust to. Drive a short distance and check the marks. If worn on the outside,,too low, if worn on the center,,too high. Adjust pressure and do again. Make a note of all four tire pressures at load desired and put in glove box for reference. You will get minor variations but it should be pretty close.
Thanks I find that usually its outside wear, the treads are uneven, ie: one tread will be raised then a couple down the tread will be lower. I will try more pressure ....
4RnrRick
02-27-2007 11:25 AM
I PASS GAS
05-12-2006 11:19 PM
