Tire Rotation
Old 04-14-2004 | 12:28 PM
blueandsilver02's Avatar
ok, so this may be a dumb question, do you rotate wheels and tires together or do you take the tires off of the rims and rotate that way. It seems to me that if you dont take them off the rim then the outside of the tire is alays on the outside and you cant correct that wearing that occurs on the outside of the front tires. Does that make a lick of sence?
b&s02
Old 04-14-2004 | 03:37 PM
induchman's Avatar
No.
Old 04-14-2004 | 07:03 PM
Suburbanite's Avatar
Muted User
b&s02
Makes sense to me but AFAIK it's simply not possible to 'correct' for the existing wear, at least not the way I drive. Whether criss-cross or straight-back/front the tires on my vehicles never 'catch up' to the cornering wear but luckily most tires I've used have more material in that area so it's never been an issue for me. As far as switching the tires around on the rims: it would just distribute the wear more evenly but I've never bothered & have never had a tire wear thru on the shoulder 1st and I've driven on tires until they started separating (don't try this at home or anywhere else for that matter).
Old 04-15-2004 | 06:18 AM
John H's Avatar
b&s02
On the vehicles I have or have had, that say I can cross them over, I rotate the tires and wheels together. On the ones that say not to, I normally only move them forwards and back on the same side, but once to help out after a bad alignment, I took the tires off the rims and mounted them on the opposite side of the car keeping the driving rotation the same. That cost me some significant $$$, I don't want to do that again unless absolutely necessary.
John
shortround
06-27-2005 10:14 AM
wood_n_soldier
17
09-24-2004 12:15 PM
jj3500
07-17-2004 07:29 AM
TON4FUN
06-15-2004 01:43 PM
RamDan03
12-08-2003 09:31 PM
Quick Reply: Tire Rotation
