Tire pressures for towing
Old 06-26-2003 | 04:52 PM
routerguy99's Avatar
Re:Tire pressures for towing
I have 4000lbs Trialer E Rated Tires I run 43 Front 40 Rear,
Old 06-27-2003 | 03:53 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
I run 65 psi all the way around all the time.
Old 06-27-2003 | 05:17 PM
Haulin_in_Dixie's Avatar
The only tires that did not get good mileage for me was a set on the front that bending to advise I lowered to 65 pounds for a few thousand miles. Took to outside edges off the tires and never could recover them. These trucks should be getting over 60,000 on a set of good tires, if not there is something wrong. I get better than that towing my weights.
Old 07-03-2003 | 12:48 PM
latitud_rt's Avatar
If you read the Door placard on 4x4 trucks it states Load Range 'E'. So for those of you running Load Range 'D'; you are asking for trouble if you are involved in an accident. You are running under rated tires for the weight of these trucks. As for inflation pressures: The government passed a new law in 2002 that says that manufacturers must provide tire inflation supplement guides in the vehicles they are producing. My 2002, 2500 4x4 has a complete manual from Michelin that says what the pressures should be at any given weight condition.<br><br>Tim
O.T
09-18-2007 12:50 PM
toupee
06-27-2007 04:19 PM
FrankB
08-17-2004 12:27 PM
Ram lon ON
06-13-2003 08:27 PM
Jones0027
15
11-03-2002 10:34 PM
Quick Reply: Tire pressures for towing
