Tips to improve towing a 5th wheel
Old 01-28-2011 | 05:20 PM
  #31
john40's Avatar
Phillip-I have no idea how to post pictures. I just tapped into the transmission line that returns from the stock cooler. I ran 1/2" hose from this line to my aux filter, to the cooler and then to the transmission. I hope this helps. John
Old 01-28-2011 | 05:41 PM
  #32
bigdaddy51200's Avatar
step 1 : create a photobucket account -free
step 2 : make an album on photo bucket
step 3 : upload pictures and save to photo bucket
step 4 : copy direct link from photobucket
step 5 : post here , and click insert image icon
step 6 : past link , click ok , repeat for more than picture
Old 01-29-2011 | 06:01 PM
  #33
annabelle's Avatar
If you ride your brakes lots, they will start to get hot, so think ahead.
Actually, if you ride your brakes slightly and keep your speed down, you rotors will stay cooler than if you stay off the brakes and use them in a harder manner to reduce a high speed that you have obtained. An exhaust brake is a good idea on steep grades,
Old 02-17-2011 | 05:03 PM
  #34
Change oil
fuel filter
air filter
trans fluid , filter , & added Derale Deep Trans Pan
Bilstein Shocks(still waiting on them )
brake pads & Rotors ( slotted rotors and pads from brake performance ) I decided not to do this job myself , got it done for 225.00
Firestone airbags ( not a easy install for a rookie )
Mag-Hytec rear Differential Cover & new Fluid
New Fan Clutch ( wire cut , Hope I fixed that problem
I weighed the trailer and it was only 11,790 almost completely load with gear.
GLHS
02-13-2009 07:58 PM
djcheez
10-25-2005 06:52 PM
67HotRod
04-15-2005 08:51 AM
nailzsn
09-09-2003 08:13 PM
jrevere
01-05-2003 10:07 AM
Quick Reply: Tips to improve towing a 5th wheel
