Timbren Installation
Old 04-23-2007 | 05:05 PM
TurboTed's Avatar
My son had Timbrens installed on his 03 today. They are sitting right against the axle without a load. the instructions on line say to have a one inch space.They say to take out the "spacer" if they are touching. However, I don't see any spacer. I do see a mounting bracket at the top of the Timbren, but I wouldn't consider that a spacer, unless they came with another mounting bracket, and the mechanic used the wrong one??
Old 04-23-2007 | 06:48 PM
Sevir's Avatar
I have the same problem. mine sits right on the axle. I double checked the Part #'s and everything.
The spacer that came with the set looks just like a hockey puck with a hole. If thats not on there, then it is removed and you will have to contact timbrens for a smaller set.
Its a alot rougher ride, but I am about to tow from Memphis to Seattle and will keep them on for that, then take them off until i have to Tow again. I dont tow all that often so taking the 20 mins to throw them on and pull them off isnt much of a problem with me.
Old 04-24-2007 | 07:47 AM
TurboTed's Avatar
I think the mechanic must have installed them with the rubber spacer in. So far my son likes the ride, so I think we'll leave it. The timbren will start to work as soon as he loads his camper this way. It's only 1400lbs. dry, so maybe this will work well? Comments?
orcaburger
12-01-2006 10:57 AM
TurboTed
07-05-2006 11:26 AM
pappyman
04-08-2005 05:20 AM
CarlJensen
02-07-2005 02:27 PM
DuaneWKKC
01-28-2005 06:11 PM
Quick Reply: Timbren Installation
