Superglide on a megacab
Old 04-28-2008 | 05:14 PM
Chubby's Avatar
Just put my superglide on a megacab, Has anyone had clearence issues with a 102 inch body and Where is your pit to the front of the trailer
Old 04-30-2008 | 06:56 PM
5Oclock's Avatar
I have both a superglide in my 01 QCSB and wide body 102" 5ver. Works great. Not sure if I could make a full 90 degree though as I've never tried it.
Don't know what you mean by "pit in the front of the trailer"
Old 05-01-2008 | 07:59 AM
Chubby's Avatar
Sorry I guess I ment how far is the pin from the front of the trailer, Mine is about 5 inches behind. I think that is where the problem is. The superglide cant go all the way back before the corner of the trailer hits.
Old 05-01-2008 | 11:26 AM
5Oclock's Avatar
My 5ver has an extended pin box which puts the pin several inches in front of the trailer. I don't know how much as I've never measured it. Pullrite's website says that in most cases even with the pin underneath the front of the trailer you should be okay. But not in all cases. I would suggest that you contact pullrite directly to help troubleshoot your issue.
Old 05-02-2008 | 12:26 PM
Chubby's Avatar
They sent me to lippert, They said not to lengthen the pin box. I am ok as long as I dont jacknife the trailer
Old 05-04-2008 | 12:06 PM
JuzPlaneKrazy's Avatar
My pin is 5-6" under the cap of my trailer and I never had a clearance problem when turning with my Superglide, and my trailer is 102" wide. I bet your good to go.
Old 05-04-2008 | 12:57 PM
FD5's Avatar
FD5
JuzPlaneKrazy,
Do you have the 18k or 24k hitch? The 18k slides 14" and the 24k slides 18".
With a 20.5k trailer I would imagine you have the 18" slide.
03CTDCO
10-05-2003 09:22 AM
03CTDCO
10-01-2003 02:44 PM
03CTDCO
09-27-2003 01:46 PM
11-27-2002 12:47 AM
Quick Reply: Superglide on a megacab
