Slide in truck camper, will it handle it?
did my first lil trip, 420 miles.Ordered bags, will try that, then maybe helwig bar if I feel it needs it. 14.4 mpg at 65 mph is that about right? was getting about 20.5 exact same trip empty, about 70- 75 though.
On another note, I've had big problems ordering online from rv web sights! why is that?
Dar
Neverhme, my apologies but I missed your comment from before about troubles ordering from RV websites. What site did you order from or try to order from? What kind of troubles did you have?
neverhme, I have a lance 845 that I bought when I had my 2002 short bed quad cab. I used it for years without issue, but when I weighed in fully loaded I found I was about 400lbs overweight. I had installed timbrens after the first trip, and it cut out the body roll tremendously. Air bags should do the same and more, as you can level the load again. I never had an issue braking, but I always drove conservatively and down shifted more than usual. Once I realized I was actually overweight, I started dumping my tanks each time I left the campgrounds, travelled with only about 5 gallons in the freshwater tank, and learned to pack lighter. I traded the 2002 (started rusting away from all the crap the northeast states use for melting ice) for a 2009 3500, and really enjoy the exhaust brake. I am sure you will be fine with your driving experience, but I recommend adding a brake if you can, it really gives you confidence on the other side of a long pull. Good luck and enjoy the TC, they are the only way to travel!
RamThatStroker
03-10-2003 02:21 PM
