RV power converter question
Old 04-06-2006 | 06:05 AM
boiler-rat's Avatar
I recently started having trouble with the 12v lights inside my RV. A couple of times a day they will ALL go off. In 15 or 20 minutes, I will hear a click coming from the power converter and they will come back on. None of the 110v system is affected, only the 12v. Is there something in the converter I can replace or will I have to replace the whole thing?
Old 04-06-2006 | 05:12 PM
qwest's Avatar
may be the thermal circuit breaker kicking off and reseting.
1. do you have all the lights and stuff on? may be overloaded
2, is the converter getting air, can't block them off,
some have a fan when they get hot, ? is it working,
or maybe its getting old and tired,
need to know if you are exceeding the design dc current,
if not may be the thermal cb is going bad,
hope all applies to your unit...
Old 04-06-2006 | 08:44 PM
FiverBob's Avatar
The first thing I would check is your battery. Even if your converter shuts down, you should have lights if you have a battery. My guess is you have a shorted battery, the converter shuts down due to overload trying to charge it, and the lights go off due to no battery.
Bowser50
13
07-19-2009 07:35 PM
pfmrof
02-18-2009 09:26 AM
RobV2500
01-31-2009 11:18 PM
Big Perm
06-22-2005 03:28 PM
Sean S
07-30-2003 10:17 PM
Quick Reply: RV power converter question
