Raising air bag equipped truck on lift
Old 04-17-2009 | 08:39 PM
belltech64's Avatar
To those who have rear air bags. Has anyone had any experiences with raising an air bagged truck on a hoist. The Pacbrake instructions address this and warn about possible damage to the bags. I was wondering what some may have done to help the problem. One solution I thought of was putting a limiting strap, cable or chain connecting the axle to the the frame. I have a need for air bags for towing, but I also have access to a frame hoist for maintenance.
Old 04-17-2009 | 09:28 PM
CD in NM's Avatar
I have been thinking about getting a pair of limit straps, for now I just use a wrap a couple chains when I put the truck on the hoist.
CD
Old 04-18-2009 | 03:01 AM
12valve@heart's Avatar
I need to put some limit straps on mine too. My Firestones say that they need to be completely deflated if a limit strap isn't used. I'm thinking of using some strap from an old ratchet load strap to make a limit strap.
Old 04-18-2009 | 04:59 PM
JohnX's Avatar
I have raised mine a few times without consequences, but I too need the limit straps at some point.
Old 04-18-2009 | 05:59 PM
Homestead's Avatar
I've never had a problem and when my truck was on a lift, it always had at least 30 psi in the bags.
Quite honestly, I never even thought about it until I saw the truck up on the lift and then it was to late anyways. They still hold air so far after probably 8-10 times on a lift and almost 200,000 miles.
I think the saving grace is if you run your factory overloads compared to not running them. There is a big difference in space when the suspension is in full droop and with the overloads in place, it doesn't pull on the bags.
Jeff
Old 04-18-2009 | 09:37 PM
Darryl&Rita's Avatar
Makes a difference if you have a full air-ride, or air-assist bags. Full air should be limit strapped, or chained.
mtdoragary
17
04-13-2013 04:56 PM
Firstgenfanatic
01-19-2008 04:40 PM
PZM123
02-05-2007 06:01 PM
BigBlue
10-11-2005 11:59 PM
AaronT
02-16-2004 10:12 PM
Quick Reply: Raising air bag equipped truck on lift
