Question about Inverters and Load
I just installed a 1200W/3200W peak inverter in my truck. I used 4AWG to go to the starting batteries from under the driver's seat and a 80A fuse at the battery. The unit seems to perform very well. I'm using the unit for dry camping to run small appliances on occasion and am not trying to use it as a generator replacement.
My question is this: I know I should leave the engine running to keep from deep-cycling my starting batteries. Will this have a negative effect on the alternator? At fulll load, the inverter pulls about 111 amps from the battery (W/V=A, (plus 10% for inefficiency) right?)
The alternator is 165A, am I gunna blow sumthin up? I don't plan to run the unit at full capacity; I bought the oversized inverter because it was cheaper than the 900W because of a sale.
Thanks for the input. I put it under the driver's seat. Surprisingly, there is plenty of clearance and airflow (no power seats here) and the outlets are easily accessible. Only drawback is having to run an extension cord inside the truck, but it's not too bad otherwise.
OG
I don't think I would use it off the alternator, or the electrical system
of the truck. Just to many electronic stuff in the new trucks,
expensive to fix,
I think I would run a seperate RV battery with an isolation relay
and only run the inverter when the RV battery is isolated from the system.
expensive to fix,
Timmer
10-02-2007 11:39 AM
