Putnam Class V Hitch - You used their grade 5, or got grade 8 bolts?
Noticed my hitch came with Grade 5 bolts. I'm not too big a fan of using Grade 5 to attach something pulling 8K lbs to my truck, so I went out and bought Grade 8 instead. Just wondering if you used the Grade 5 that came with it, how it held up, and how much you tow?
Did I do the right thing getting Grade 8?
8 grade are stronger Dave....
But having installed them with the supplied hardware, and for what you are going to tow, you should have no problems, those bolts are the max size that the hitch was engineered for, the grade 8's yes they are stronger and a better insurance policy, but your grade fives should suffice... I have not seen a hitch break yet.. (Knock on wood) BUT my experience comes from welded on recievers on both my heavy duty trucks that ive had...Best of luck!
Tx
Tx
They use grade 5 because they tend to flex more without weakening. The grade 8 will after enough pulling on them snap, they are the stronger in tensile strength but that also makes them brittle when they do flex.
http://www.boltdepot.com/fastener-in...ade-Chart.aspx
I would stick with the grade 5. Also, they will be less impact resistant in cold weather.
FBs555CTD
28
05-30-2009 08:10 PM
lawnmaniac883
04-19-2009 05:21 PM
Joe T
06-04-2007 08:36 AM
