plug for gooseneck trailer
could someone please tell me as i am new to gooseneck trailers,
plan to purchase one shortly what i need to know is there a wiring harness for it. is there one that plugs in underneath and goes to an outlet in the bed or ? do you just plug into the one on the bumper ( I have towing package already)
My other truck ( ford) has a outlet in the bed for a gooseneck but i bought it this way.....
thanks
thanks
If you use the 7 pin RV plug on the trailer it's the same as the factory Dodge plug if you have a trailer tow package. You can plug it into the one in the bumper but you'll need allot of cord if you turn tight to the right. You can get the 'in bed' kit from e-trailer for around $60. IIRC it's a plug and play unit, no splicing required.
With age comes the cage
I installed an in-bed harness, I don't have to worry about the paint or ripping things apart when I jackknife the trailer. It takes less than an hr. to mount it and wire tie the harness into place. All connections are water tight with no cutting / splicing
Link to harness listed in my sig:
http://accessories.etrailer.com/sear...0137&x=42&y=10
Pic of my setup:
Pic of my setup:
Put a plug in the bed.The bumper plug will make a unreliable connection. Basically the factory plug is junk. It was in my 04 and it is in my 06. The better quality plug in works every time.
I have my trailer wired so the cord comes off the middle of the neck of the trailer(GN) and goes to the bumper plug on the truck. A rubber bungie takes up the slack and keeps the cord off the tailgate.
dws35
01-09-2007 01:31 PM
SkyHarborCowboy
10-17-2005 10:13 PM
Dodgezilla
12-07-2004 09:41 PM
Amish hauler
04-08-2004 07:07 PM
