Painting 5th Wheel Plate?
Old 01-08-2006 | 07:54 AM
PZM123's Avatar
It was powder coated from the factory.The 1st time I hooked up the new trailer the pin was warped & put two big scratch's on the plate. Dealer replaced the pin box & put on a nylon friction ring. After last tow of the year I sanded it down, primed & repainted it. After about 8 or 9 weeks of sitting in the garage I put it back on & towed around 100 miles. When I unhooked it the paint was smudged up & all over the nylon ring. So has anyone found a good paint or tried the do it yourself powder coating ?
Old 01-08-2006 | 01:53 PM
Fronty Owner's Avatar
Powder coating is probably the only hting your going to find that will stand the abuse.
I have never tried the DIY powder coating system.
Old 01-08-2006 | 03:10 PM
Brock's Avatar
why would you paint the 5th wheel and worry anyhow...dont you just put grease on like the ones on the rigs?
Old 01-08-2006 | 05:33 PM
PZM123's Avatar
No I don't use grease. I use a friction ring/ lube plate.
Old 01-08-2006 | 06:39 PM
The benefit of the grease is that it will prevent the bare steel from rusting. If your towing enough to keep the rust from forming, I wouldn't worry about some scuffed paint. Otherwise drop the money to have it repoweder coated or shoot some high weight grease on there.
Old 01-08-2006 | 08:19 PM
JKM's Avatar
JKM
Just smear some grease on it, that's all we do at work ,no fancy special grease , finish lubing under the truck , and pull the hose from the greaser over to the 5th wheel plate , use the same ol grease.
LemonDodge
09-07-2019 03:51 PM
cLAYH
12-01-2010 08:10 PM
LemonDodge
09-16-2010 07:33 AM
SeanB23
04-16-2010 06:20 AM
Palmetto_kid
12-02-2008 02:52 PM
Quick Reply: Painting 5th Wheel Plate?
