Onan Generator hour meter mounting
Old 02-11-2012 | 08:25 PM
travelingman's Avatar
Bought a new to me 5th wheel camper with a Onan gen set on it . The unit does not have a hour meter on it . I know these can be purchased from several places but do any of you know where to hook up at ? Its basically just a time keeper so any circuit that stays hot while its running will work. But since it does not have a on off switch only a rocker style switch to start it I was just wondering where is a good place to connect it ? Thanks
Old 02-11-2012 | 08:29 PM
FiverBob's Avatar
Mine is built into that start/stop rocker switch. No reason to pull it yet to check out the wiring, but I assume it could be hooked up right there.
Bob
Old 02-15-2012 | 11:35 PM
robertleo's Avatar
I have an Onan Microlite 4000,there is a plug in on the left side for the hour meter and the remote start switch....robert
Old 02-19-2012 | 12:05 AM
when you say remote switch are you talking about the inside the3 camper or the one on the unit?
Old 02-20-2012 | 01:22 AM
robertleo's Avatar
Inside the camper....Robert
Old 02-21-2012 | 11:37 AM
Thanks robertleo I would think that rocker switch on the Gen set itself might be just like the one inside. So maybe I could mount it down there an not have to bore a hole in my wall or get another pannel .
Old 02-22-2012 | 11:13 PM
robertleo's Avatar
I mounted mine up high above the generator,which Onan do you have?.....Robert
jmccart
04-04-2008 05:47 PM
Tommy93w350
07-28-2007 11:20 PM
MoparMarv
09-26-2006 11:33 AM
DFD536
05-24-2004 08:45 PM
TON4FUN
01-28-2003 01:46 AM
