Oil Bath Hubs
Oil Bath Hubs
Explain to me what the advantage of oil bath hubs are on a small car trailer.
Additionally would the washer in oil bath hubs dry up and then cause the oil to leek out.
THanks ROb
THanks ROb
i personally think it is a better system i have less problems with them under heavy loads the oil seal is no likely to fail than the grease have some going on 40 years old the only problem i ever had is our idiot employees will crack the plastic see through housing or pull the filler plug off and lose it
The biggest advantage that you can check the condition of the lubricant at a glance. If its low you can add fluid. If its milky you know water got into it.
With grease you really don't know what going on in the hub unless you pull it and inspect.
I've had them on my boat trailer for over two years. As far as I'm concerned its got grease beat hands down.
I've heard that its not the best way to go for trailers that sit for long lengths of time. Supposedly the bearings and spindle can rust if the oil isn't flowing over them frequently. My boat sits for a month or more at a time in the Winter and when I pulled the hubs last week to add disc brakes the bearings and spindle were absolutely rust/corosion free.
Like I said,I'm sold.
With age comes the cage
I have the EZ Lube axles on my rafting trailer (31' GN That gets backed into the river a lot)..I prefer it over the Oil Bath as there is no voids that can get filled with water, Whenever you put grease into the EZ Lubes it pushes the old grease out the front.. I tried to get my 12K disc brake axles with the EZ lube option but it was not available, My concern with the Oil Baths if you develop a leak you could loose lubrication faster than with the grease filled axles.. just my point of view for my particular applications
chaikwa.
And out the back past the grease seal, which then gets all over the brake shoes and drums. Yes, your bearings get lubricated, but there are a lot of negative aspects of the EZ Lube's; you can never tell where ALL the grease is going, can't tell if the bearings actually NEED grease, and if they DO, how much is enough? Dexter says one pump from a grease gun is adequate, but how often? They're a good idea but they need to refine the concept a bit before I'M sold on 'em!
chaikwa.
chaikwa.
Changing the oil is really easy. Unscrew the cap and let the old drain out. Put the cap back on and re-fill with oil. It might take 15 minutes to do all 4 wheels on my boat trailer.
chaikwa.
chaikwa.
With he axle elevated simply spin the wheel while pumping in the new grease, it will be evenly distributed and the old will come out through the front hole. The EZ lubes have a HD Seal as they now what it will have against it.. And like I've never changed out a seal on oil baths that has leaked out on the brakes
Although you are correct that some oil seals do leak, it is usually caused by a previous repair done incorrectly or the brakes overheated, as far as longevity goes, an oil bath bearing is far superior.
As far as EZ lubes go the idea is great but I agree with Chaikwa 100%. Dexter uses a single lip seal for you to force the grease against, failing almost all the time.
Tim
chaikwa.
Tim
Tim
What of continual water submersion? I found that the hub full of grease is less apt to allow water in...The Rafting GN Trailer(pics in profile) I built is going on its 3rd season with no problems on the EZ lubes or its associated seals,bearings and brakes...If in fact they only install a single lip seal it could be upgraded.
Tim
Tim
91oldranchtruck
01-31-2011 09:45 AM
