No juice from truck to trailer
I dont have any juice going to the power terminial on my 7 pin plug on my truck. I have checked all the fuses that are labeled trailer tow. I am not sure where to start checking next. Never had to look into a issue like this before. Any help or suggestions? Thanks Bret
Are you using a 12 volt test lights and testing with the key on. Once I reversed the test light by hooking the aligator clip to a jumper cable to positive and then checked each pin looking for a ground. Kinda of backwards but it will light if you find the ground.
Yes I am using a test light. My factory 7 pin plug has all the pins labeled so I know which pin is for what. I have no juice with key on or off, and no juice with test light grounded to the bumper or to the ground pin in plug. Thanks Bret
Silly question, but have you checked the fuses under the hood, not just the ones inside the door? There is one under the hood I remember that is not labeled for trailer tow. I'll see if I can find the one for sure in the wiring diagram.
Here is the diagram. I am pretty sure that the fuse # in the diagram should match the fuse labels on the cover under the hood. Should be #8 according to this. Also I see a relay in the wiring diagram too, but the power to the trailer should be hot all the time IIRC.
^^ All of the other circuits to the trailer are separate. The power feed for things like trailer battery and emergency brake battery are fed thru another fuse, the one listed in the pic above. You don't see any lights in the wiring above because they are on a different circuit.
Or a bad connection at the plug in jack under the truck ,about where your feet would be , and near the front fender. See if you have juice going into the connector and out the other side going to the rear of the truck.
Found the cause! broken wire by the spare tire. Fixed that and all is good for power now. Still dont have trailer brakes though. Please feel free to read my post on trailer brakes and see if ya can help me out again. Thanks to all!! Bret
Chris
I had the similar problem there is a single blue wire taped to the stearing column way up in there that needed to be spliced to the blue wire on the harness. Spliced it in and it worked perfectly.
razor6
22
01-20-2006 03:43 PM
djcheez
10-15-2005 04:13 PM
Ripper406
04-06-2005 07:38 PM
04ctd
04-05-2005 11:59 AM
