Need a measurement for 5th wheel placement
I like your design idea, very simple and strong. Although, I think you should center the ball on top of the axle on a four wheel drive truck with a diesel motor. They are not a semi and already have enough weight on the front axle. IMHO
Not my design, but is standard proceedure for truck fifth wheels. Take a semi weight measurements and axle weight measurements and roughly cut it in half on all weight measurements and you then have what you are building. A semi it is really and all the specs apply. What works for one works for the other. At about half of or a little less than half the weights of a big truck.
A single axle big truck is running 18 to 20k on the drive axle, we run to about 7k on these and some hot shotters run 10k regularly. The steering axle on a big truck is comfortable at about 10k and yes virginia I realize that in some states they run 14k and higher. On ours we run around 5k on the steering. The chassis lengths and the trailer lengths are about the same and sometimes even longer. We are running our trucks as a single axle semi, don't ever forget that and then you can use the tried and proven formulas for big trucks.
In most cases you cannot get much ahead of the axle centerline in a pickup and it does work well. You hear a lot about sway on the pickups and the reason is the pin mounting. The further foreward the more stable the ride.
He is not reinventing the wheel, he just simply wants to build his own G/N hitch. Probably does not matter if it may be time consuming, or even more expensive. He just wants to build his own. The guy was just looking for a little help, GEEEZ.
Reinventing wheel
A pict. is worth a 1000 words. I p.m'd wyododge to thank him for those pict's.My truck had a hide a ball on it before I bought it.The guy thought I got too good a deal and took it off. I fully understand what your design is Haulin ,but I've got access to a breakpress to make it 1 piece less bolts to come loose. A better design in my book. I just wanted to feel you guys out on pin placement. The rest I can handle as said above 18 years in steel fab. (Asphalt equipment)Thanks again everyone, Nate
toyota31
04-03-2007 10:04 PM
royta
11-06-2006 08:19 AM
dcorneli
03-12-2004 08:13 AM
