Need info on best way to lower 03 dually
Assuming it is 4WD?? If so, there are small helper/shim leaves below the main leaf packs in the rear.....they can be removed and shorter u-bolts installed.....I just recently helped a buddy do this to his 05 2500 4WD.....it knocked about 2" out of the rear ride height and allowed the 5ver he was towing to sit level.
BTW, welcome to the board.....lots of good reading and info here......don't forget to fill out your sig - it helps everyone help you better.
First have you hooked up the trailer and loaded it up to see what the actual ride height is
Mine is not the dually however the rear sits down 3" when loaded with my 5VR and I have the exact same rearend sanz the extra wheels
http://www.klenger.net/dodge/lowerin...d/slide01.html
GCrocker
08-13-2011 09:20 PM
rock crawler
21
02-09-2009 09:11 AM
chumstone
07-24-2007 10:55 PM
