mega cab and a fifth wheel
Old 07-18-2006 | 11:55 PM
doznfire's Avatar
Who has a fifth wheel set-up with a mega cab? And what, if any issues have you had regarding cab clearance.
Old 07-19-2006 | 08:46 AM
rockhound's Avatar
if i can tow a 5er you should have no issues, there isn't a truck anywhere that won't have clearance issues on a 5er, if you go too far you are screwed
get a sliding hitch so that you have options when you need them
most 5er have options for lenght of the pin box, maybe get the longer one
mine was 18" from the factory but they had a 26 inch optional pin box
look into the rv5 extension if necessary
8 passeneger ram
http://www.sendpix.com/albums/06071222/8tzpgk6lrc/
Old 07-19-2006 | 09:43 AM
doznfire's Avatar
What is the length difference between the mega cab bed and a standard short bed if any? I am thinking about building a custom pin box for my trailer but I don't want too have issues on the other end of things,worrying about it hitting the bed rails.If it becomes too big a worry I'll build a flatbed.
Old 07-19-2006 | 09:44 AM
MX429's Avatar
I don't have a 5th wheel set up, but I do pull a full width enclosed gooseneck with my mega cab. I had to make a few adjustments for it to work. I had to get the 9" extension from PopUp for the trailer. This set trailer back 9" to give me more clearance to begin with.
When I had my hitch installed, after careful consideration, it was installed a few inches behind the axle. I know many people will absolutley blast you for saying you have the pin behind the axle, but it works fine. With it behind the axle, the load is place on the rear of the truck and not on the front axle. While not the setup for hauling extreme loads, the truck can easily handle the weight of my rig.
I wouldn't reccomend this with any truck, but the mega cab DW is more than capable of towing the combo this way. The truck is long, and with the CTD, there is plenty of weight over the front axle.
When I connect the trailer, the truck sits level (rear end goes down some). The front does not come up at all. The truck rides down the road very good and I have no bucking from the trailer.
The mega cab bed is short. If everything was in the standard position without making changes, I could probably hit the cab when turning going forward. Clearance is something that has to be considered on one of these rigs.
doznfire's Avatar
hey rockhound,,nice rig!
Old 07-19-2006 | 09:46 AM
doznfire's Avatar
MX,
how heavy is your trailer?
Old 07-19-2006 | 10:03 AM
MX429's Avatar
I have never weighed the trailer. That is something that I plan to do soon. I am going to make a trip down to the local trck stop and weigh the truck alone and then with the trailer. I wanted to get the weight oon all of the axles when loaded and unloaded.
I'll let you know the results.
Old 07-19-2006 | 11:32 AM
MikeyB's Avatar
MX,
Are you in Willis? I grew up there.
MikeyB
Old 07-19-2006 | 11:42 AM
MX429's Avatar
Yeah, I am just north of Willis......about halfway to New Waverly.
Old 07-19-2006 | 01:18 PM
Buckshotmckee's Avatar
No difference Kyle, there both 6.25 in length. Your going to need a slider to keep the nose from kissing the rear window in sharp turns.
Old 07-19-2006 | 03:06 PM
doznfire's Avatar
I thought they were different.I thought the shortbeds were 6' 6'' long..
Old 07-19-2006 | 04:29 PM
According to the spec sheets over @ DC the there 6.25?
Old 07-19-2006 | 08:49 PM
rockhound's Avatar
i have about 5'9" of bed left after the conversions
turns going forward are not a problem i have pulled uturns with my 5er and and a small utility trailer behind it 59'9" tip to tail with no issues it would be more likely to be tight backing up
you may have to adjust your pin bax to move the rig back a little
my rv5 extension cost me 350 or so
misterKTM
02-11-2015 01:21 PM
jimbo486
13
11-05-2009 09:17 AM
tank146
05-23-2007 12:59 PM
jrussell
05-08-2007 09:24 PM
4x4dually
05-11-2006 10:46 AM
Quick Reply: mega cab and a fifth wheel
