Jake brake sound?
Old 04-19-2006, 10:08 PM
wap
wap's Avatar
Jake brake sound?
What does an exhaust brake sound like with a straight pipe?
Anything like a big rig?
I understand it is not the same concept but have never heard one.
Old 04-19-2006, 10:29 PM
RAMRODD's Avatar
Have you ever heard a 7.3 powerstroke straight piped when cold.With high idle, sound a lot like that!!!!
real loud hissing sound ???
I had one on my 2000/2004 with straight exhaust I think they are ok with muffler.
In my opinion they don't sound good at all!!!! They do warm the engine fast!!!
Old 04-19-2006, 10:33 PM
bnold's Avatar
I would have to agree with the loud hiss... I like the sound though, turns a lot of heads coming off the highway at high RPMs...
Old 04-20-2006, 12:30 AM
rebal's Avatar
my truck ,in the cab sound is like a compression engine brake.
at the tail pipe a very loud hissssssssss
Old 04-20-2006, 01:50 AM
quantum610's Avatar
The 5.9 cummins can accept a real jake.....a change in exhaust valve timing. Everyone is thinking of exhuast brake sounds. A jake brake sounds way better.
Old 04-20-2006, 10:15 AM
FiverBob's Avatar
Sure ugly when you are camped right beside an off ramp from the interstate and you are trying to sleep.
Old 04-20-2006, 11:24 AM
Registered
blackdiesel's Avatar
i didnt think they made a real jake brake for the 5.9's??? (the one that goes on the head, and controls the valves)
however i have an exhaust brake. its just a hisssssss. dosnt sound cool, but it works good
Old 04-21-2006, 04:41 PM
ke5adb's Avatar
just get a big PA speaker by the exhaust that automatically plays the sound of an actual "jacobs brake" when you turn your exhaust brake on.
Old 04-21-2006, 10:51 PM
spitfire9137's Avatar
You sure on that one?
Old 04-22-2006, 10:21 AM
DSjockey's Avatar
Well I certainly hear the hiss in the cab but I also hear the (semi like) BBBBBbbbbrrrrrrrrrr
Old 04-22-2006, 08:23 PM
Jeff in TD's Avatar
That probably describes mine pretty well. At idle, it is a hiss, but when in operation with a load it has a bit more Bbbrrrrr... sound a bit more like an engine brake...
Old 04-24-2006, 03:24 PM
Cowboy_Customs's Avatar
Or if you want the sound of a jake, buy a 7.3 IDI (not powerstroke) ford and downshift it when slowing down or going down a hill! You out to hear mine at 60 comming off the highway downshifting into 2nd (with straight pipe too) hehehehe sounds like a semi with a 6 stage jake!
Old 04-24-2006, 03:34 PM
akghound's Avatar
Question Where
OK, I want to know more about this.
Who, What, Where, How Much?
Can you post a line or post more info on this?
Thanks .... Ken Gardner
Old 04-24-2006, 03:48 PM
G1625S's Avatar
I read somewhere that the injection setup also plays into weather or not an engine can accept an engine brake, which is why the 5.9 can't take one. You've got to be able to cut the fuel or there'd be raw #2 pumping out the tailpipe, right? Lemmie go dig around...
Old 04-24-2006, 04:19 PM
Forrest Nearing's Avatar
the 5.9 can't accept a jake...
and if it could, your rear tires would probably be flat spotted the first time you hit it empty
Quick Reply: Jake brake sound?
