Increasing weight capacity??
I have a 2004 HD 3/4 ton. Has rear air bags and overloads. Tires are E rated 17". It is a 4X4 quad cab. Question.....What if anything can be done to increase the load capacity......other than getting a dually, cant do that right now. If something can be done I will get it re-rated if possible
load range "G" LT235/85 R16's
If you are in Las Vegas, go to American Tire on Boulder highway and get their load range "G" which is rated at 3700 lbs each for single rears. I got em on my duals and they are rated at 3400 lbs each in dually configuration at 110 psi.
Z rated tires will not increase the weight "rating" of your truck. Exceed that and you start pushing the envelope on lots of other nasties happening, like trying to get stopped when that annoying Honda with the snorter pulls out in front of you.
Bob
Bob
Nothing and nobody is going to re-tag the sticker on the door jam with a higher weight and load range G 16's will not fit on your truck.
Why don't you tell us what you are trying to do....
johnm
http://photos.thedieselstop.com/show...hp?photo=27549
Fisherguy
04-12-2006 02:53 PM
tobyw
04-19-2005 12:54 AM
Ripper406
12-14-2004 07:45 PM
