how much weight?
how much weight?
were thinking about getting a skid steer with a brush head and a new trailer. my question is these two together will weigh about 16,000 lbs. with my truck is this ok? id be around 23-24,000 maybe more but it would just be shop to job site. we are a mountain locked valley so theres some grades around. im thinking to get a jordan controller abd this will be a pintle hitch. ive got a dana 70 and camper springs.
Get yourself a class 5 receiver.........I see alot of guys towing big skid steers on 8 ton floats with CTD's.............a good controller, trailer brakes and the right hitch and you will be fine, IMO ........might have to check locals laws and re-register for the approprate Gross weight...
Since you say you're getting a new trailer- get a gooseneck trailer!
No hitch capacity problems to deal with, and the goosenecks handle MUCH better than a bumper pull. You can haul MUCH heavier with the gooseneck- the pin weight of the trailer sits in the bed and adds to your trucks GVWR.
For instance;
My truck has GVWR of 8800 lbs. It weighs empty at 7200 lbs. 8800-7200=1600
That means you could LEGALLY haul a gooseneck trailer with a 1600lb pin weight.
Course, these trucks can handle more weight than that!
1600lbs wouldn't even put you down onto the helper springs...
For instance;
nono of out other trucks could be set up for goose neck or id love to. i thought i had a class 5 that was rated 10000 but ill have to check again. thanks for the in sight guys
Class 4 is rated for 10,000 lb with a w-d hitch.........class 4 is factory equipment...........a class 5 is rated for 15,000 lb, typically........some seem to be 14,000 lb.......
Purplezr2
07-25-2011 04:31 PM
