Hood louvre?
Hood louvre?
Has anyone ever considered putting a 98 Jeep Grand Cherokee hood louvre on the turbo side of the hood? I haven't seen them in person under the hood but they are supposedly pretty well engineered to let tons of heat out and no water in...
Patented part adds more zip to Jeep engine
Detroit--At a quick glance, buyers probably won't spot the difference, but the 1998 Jeep Grand Cherokee's new 5.9l V8 features a plastic component that helps make the vehicle's performance even more impressive. The part: a molded functional hood louver assembly.
The assembly resulted from a coordinated effort between Jeep-Truck Engineering and the Interiors & Molded Products Div. of Cambridge Industries, Inc. (Madison Heights, OH). Consisting of two molded parts--louver and water distribution tray--the assembly keeps the engine cool while allowing zero water intrusion. Chrysler considered the combination unique enough to be patented.
The louver, which requires extremely high heat performance, is injection molded from AmodelŽ, a 33% glass-filled polyphalamide from Amoco Polymers, (Alpharetta, GA); the water distribution tray is produced from MinlonŽ, a polyamide/mineral resin from DuPont Engineering Polymers (Wilmington, DE). The louver nestles into laser-cut openings in the metal hood. The tray design and material cost-effectively disperse water to the outboard side of the hood.
The two-component assembly combines design engineering skill with production expertise for optimum performance. The louver material, processed at 625F, offers high heat resistance without distortion or sag.
Cambridge Industries served as the Tier I supplier for the project primarily because of its performance on the louver for the Dodge Viper. While the Viper component provided only air distribution, the engineering assistance and production quality insured the timely, appropriate response required for the Cherokee project, Pat Muldoon, Project engineer, reports. "Most important," Muldoon continues, "the performance requirements-- including zero water intrusion--were met, with considerable part cost savings."
Looks like parts would be about $150 new from dodgeparts.com. I wonder if this would yield any sort of EGT decrease? Sounds like a junkyard job to me...
Dougk
01-30-2010 12:11 PM
Eddy Reyes
18
06-28-2007 12:06 PM
