Hensley Hitch
Hensley Hitch
Wondering if anyone has or is using this hitch? My son's bumper pull toy hauler sways bad with his UTV in it, too much weight behind the axles. His WD hitch is heavy enough and he's using two friction sway controls. This sounds like the fix but it is expensive!
i use one on my 30' warrior and it gives me a warm fuzzy feelin' when i pass the big rigs and they're the ones swayin'. little pricey as stated but gauranteed for life and it works. they'll send you a free video if you call or e-mail them. after watching the video my wife said "BUY IT" and she was serious. and no, i have no affiliation with them. one note, if he pulls his hauler out into the dunes or on uneven terrain and unhooks it can be a little tricky getting it lined back up, not impossible, but agrevating.
I have and use a Hensley hitch also, it is expensive new but they are available used if you know were to look. They are being sold by people that go from a TT to FW. Also they are not unique to a trailer they can be moved from trailer to trailer, TT that is No problems hooking up here as long as you unhook correctly...
I use a dual cam sway control. Mine is made by Reese. It is used alot in the RV towing world,I found out about it from being on the openroads forum.
Also, its alot cheaper than the hensley and it will bolt up to his WD bars. It works in conjunction with the bars and WD setup.
truckjunkie
05-30-2006 02:12 AM
