help tow
Old 04-10-2011 | 07:08 PM
lane22's Avatar
help tow
i buying fifth wheel camper note camper is 11,900 lbs.need to know the do,s and don,s of tow with 2003 2500 stock 5.9 ho.
Old 04-10-2011 | 11:54 PM
Jeff in TD's Avatar
Your hitch weight will likely be around 2000 pounds.
Hitch wise, I'd suggest one that pivots 4 ways. If you have a short box I'd look for an auto slider. In a non-slider I'm really happy with b&w's turn over goose neck ball with the companion hitch.
Brake controller wise, once you've used a fluid pressure proportional you will never go back. I really like my brakesmart, and I've heard good things about maxbrake.
Old 04-11-2011 | 07:20 AM
Don T's Avatar
Wife just called from work at the post office and told me my Maxbreak is in. I will be installing it right away . My other controller is toast and a pain to adjust for town and highway driving. it will be nice not to have those two buttons to adjust again.Now I can take my fiver to the tire shop for new Michelin ltx . I can soon go camping
Old 04-11-2011 | 09:03 AM
67HotRod's Avatar
Tell us more about your truck. If its an auto, a trans temp gauge should be installed.
Old 04-11-2011 | 11:59 AM
Jeff in TD's Avatar
An exhaust pyrometer is also a must with mods, and nice on a stock truck.
In the mountains an exhaust brake is also really nice.
Tire wise I went with load range G. Overkill for the weight on them, but they run cool and never cause a problem.
Old 04-12-2011 | 08:36 AM
yepuhuh's Avatar
I added rite ride air bags to mine to help level out the 5th wheel to the truck and it also helps in the 5th wheel not being so jerky as you pull it alone. I put the 20k Curt slider hitch in it too. Works great!
Also I have a 2500 5.9 with auto tranny and I've read a lot on here about a gorend transmission specifically beefed up to do the load.
We got our new 5th wheel in decemeber and it has only been towed from the shop to our house and back 2 times. We are trying to take it camping and are finding most camp areas we want to camp in have a limited anmout of sites available for a 40 footer....
thomas winter
23
12-09-2012 08:27 PM
davelinde
18
07-14-2008 08:34 PM
Sharsha
02-20-2005 01:47 PM
lezmark7
06-30-2004 08:22 PM
DRM
88
04-06-2004 09:16 PM
Quick Reply: help tow
