help me understand
Old 02-07-2005 | 04:48 AM
95ram's Avatar
help me understand
How much weight I can tow with my pickup. I see people talking about the sticker in the door that says something about gross vehicle weight. I'm not understanding this. To make things simple can someone just tell me how much I can tow with my pickup.
Old 02-07-2005 | 07:27 AM
natstayl's Avatar
Lots of info located in the Towing forum about GVW and GVCW. Here's one.https://www.dieseltruckresource.com/...ighlight=26000
Hope this helps.
Nat
Old 02-07-2005 | 08:54 AM
95ram's Avatar
Thank you for the link, but it seemed to do more with campers in the bed of the pickup. I'm more interested in how much I can tow with my pickup. I'm wondering if my goose neck weighs 16,000 is this ok.
Old 02-07-2005 | 09:09 AM
RustyJC's Avatar
IF you're asking how to evaluate where you are vis-a-vis the manufacturer's ratings, here's a method to get you there:
First, you'll need to know the actual laden curb weight (LCW) of your truck. This is the scale weight with full tank of fuel, driver, passenger(s), options, accessories (i.e., gooseneck hitch, toolbox, etc.), cargo, etc. just like you'll be heading down the road. With the LCW as well as the truck's GVWR (on the driver's door sticker - 8800 lbs in your case, I believe) and the truck's GCWR (either in the owner's manual or on the Mulroney {new vehicle} window sticker - 20000 lbs in your case, I believe), you can use the following formulas:
Truck's GCWR - Truck's LCW = maximum allowable total weight of loaded trailer
Truck's GVWR - Truck's LCW = maximum allowable pin/tongue weight of loaded trailer.
I suspect a 16000 lb gooseneck is going to put you well over both ratings.
Now, will the truck handle the load? Yes, but that's a different discussion.
Rusty
Old 02-07-2005 | 09:24 AM
95ram's Avatar
Thanks Rusty. Thats what I wanted to know
Old 02-07-2005 | 10:05 AM
mestdagh's Avatar
The towing guide from the dodge site might help also:
http://www-5.dodge.com/vehsuite/Towi...icle=ram_truck
Old 02-07-2005 | 10:13 AM
RustyJC's Avatar
The problem with the towing guide is that it gives a trailer tow rating (1.) based on an unrealistically low curb weight (i.e., a base truck with no options or accessories and only a 150 lb driver) and (2.) totally ignores the GVWR which will be exceeded long before the GCWR is approached when dealing with a SRW truck pulling a gooseneck or 5th wheel. The formulas I gave above are "real world".
Rusty
Old 02-07-2005 | 07:52 PM
Patrick Campbell's Avatar
Check out the link in my sig !
Old 02-08-2005 | 06:57 AM
natstayl's Avatar
NJ neither of the links work for me. Might wanna check on them.
Nat
Old 02-08-2005 | 10:16 PM
It should work.... what error are you getting.
The proper link is http://xj.cdevco.net/auto/dodgetowing/
Old 02-09-2005 | 12:51 AM
Rattletrap1's Avatar
remove the last slash....it sends browsers in strange places.
Old 02-09-2005 | 05:23 AM
natstayl's Avatar
All three links are working today. We now return you to your normally scheduled program.
Nat
4doogie
07-02-2004 08:43 PM
RUSVD
06-23-2004 09:26 PM
Quick Reply: help me understand
