Hauling a truck with stacks?
Old 05-19-2006 | 01:29 PM
SmokenRam's Avatar
Heck, I thought i was just asking a dumb question. Glad to see i'm not the only one debatiable on this subject. Thanks guys. Think i'll cover them just in case.
Old 05-20-2006 | 05:15 AM
Deezle98's Avatar
Originally Posted by TAS05CTD610
Besides if a turbo spins one way to build boost, and it spins backwards from the exhaust (your pushing air in through the exhaust, out the air box) wouldn't it develope Vacume???
I would cover them. You never know what could get in there, rain, ect. I doubt the wind would be enough to move it bad enough to cause damage but who knows. We should find a guy that dosen't want a turbo, spin it backwards with air through the exhaust, and only have a loop oil system on it, see what happens. Since stock there is oil on the bearings (not moving) it should lubricate enough to keep it from seizing.
Um no it would still spin the same way, the air passing over the stacks creates a low pressure in the pipe causing air to rush out of the pipe spinning the turbo as normal, in theory of course, who knows if there is actualy any truth to the matter.
Old 05-20-2006 | 07:23 AM
Patrick Campbell's Avatar
It is going to spin ...it does not take much of anything to spin and there is no oil circulating so why not just cover it up
Old 05-20-2006 | 08:26 AM
BearKiller's Avatar
Of course, a man could be climbing around up there, tying lard cans over the stacks, slip, fall, and break his neck.
Old 05-20-2006 | 10:02 AM
Camotanker's Avatar
why not stop there? wouldn't a standard exhaust pipe cause the same issue?
Old 05-20-2006 | 07:26 PM
HorseHauler's Avatar
AKA... Venturi Effect
Old 05-22-2006 | 06:48 AM
durasmack's Avatar
For what its worth, the tubes that camping chairs come in fit nicely over 5" stacks......
Old 05-22-2006 | 09:48 AM
apwatson50's Avatar
I was thinking the same thing, are is still passing over the tip of the exhaust. Also just how fast is the turbo going to spin? Fast enough to really ruin the bearings?
Also would it spin the turbo if the truck had a muffler? A stock muffler and not a straight through muffler.
Guess there's only one way to find out!! Guy laying in the engine compartment while the truck gets towed down the road.
Old 05-22-2006 | 10:28 AM
Sidewinder's Avatar
I believe the final answer was a very definate maybe.
look here---> Hauling a truck with stacks
Very interesting. This thread seems to CONFIRM the definate maybe - so it must be true!
Old 05-23-2006 | 08:17 PM
JonD's Avatar
cover em . not a boost issue, no oil = bad . bearings dont like that
C Minus
22
04-15-2008 02:31 PM
nfsommer
21
04-04-2007 03:45 PM
rockittboy
02-03-2006 12:38 AM
Craig93
07-03-2004 02:27 PM
PistolWhipt
32
02-19-2003 04:40 PM
Quick Reply: Hauling a truck with stacks?
