Hauling a truck with stacks?
Old 05-18-2006 | 04:52 PM
SmokenRam's Avatar
I don't know if this is true or not , but i have heard of some people say if you haul a truck with miter cut stacks on a trailer, you need to cover the tops of stacks b/c it will spin the turbo dry. Is this true or false. I could see this mybe on a truck with the stack out of the hood. But not so sure with them in bed. Thanks
Old 05-18-2006 | 05:25 PM
TN Redneck's Avatar
There was a discussion on that subject a while ago. Try a search for it. I would for you but i need to get home and spend some time with my kid.
Good Luck
Old 05-18-2006 | 06:14 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I believe the final answer was a very definate maybe.
look here---> Hauling a truck with stacks
Old 05-18-2006 | 07:06 PM
oestreich84's Avatar
I don't remember ever seeing covers on the stacks of trucks and tractors going to pulls. I think they should know. Although, it does kinda make sense.
Old 05-18-2006 | 07:38 PM
Willy91's Avatar
Cover it, we hauled a tractor one time and when we stopped at a rest area you could here the turbo spinning. Why risk it just duct tape it. Are you getting you Head worked on?
Old 05-18-2006 | 08:52 PM
Pooter's Avatar
Didnt know that, thanks for the heads up...
Didnt realize enough air pressure was generated just from airflow when towing....
Old 05-18-2006 | 08:56 PM
SmokenRam's Avatar
The truck is done. Just got it last night. Runs good too. I'm going to Lima OH for the truck JAM this weekend. Hauling it up there. I did a search but couldn't find anything. So is it a mybe or yes or just do it just incase. Thanks Chris
Old 05-18-2006 | 09:10 PM
bmoeller's Avatar
It is able to spin because of valve overlap. It is where both valves on a cylinder are both open a bit on the exhaust stroke.
Old 05-18-2006 | 09:15 PM
HorseHauler's Avatar
after reading everything... why take the chance? I would cover deffinately
Old 05-18-2006 | 09:28 PM
kingofdodge7131's Avatar
oh i get it now i was confused, i thought you were using yoru truck to pull a trailer and the truck had stacks im like what kind of sense does this make?
Old 05-18-2006 | 09:50 PM
blackdiesel's Avatar
Registered
ok ive covered mine in the past and ive seen big rigs with covered stacks but seriously, how much air could possibly get through the motor? im not saying dont cover them, because i have, but really is it enough air to really hurt anything?
Old 05-18-2006 | 11:14 PM
BearKiller's Avatar
The only scientific way to answer this, once and for all time to come, is to have your most observant affiliate to sit in the cab of the truck being hauled, keeping his eye on the boost gauge.
If it spins up enough to develop boost, then stuff old pillows down in the stacks.
If it is just sort of spinning along, then I wouldn't worry about it.
Old 05-18-2006 | 11:28 PM
Deezle98's Avatar
Um there is no way its gonna build any boost. It takes many thousands of rpms to make a turbo build boost.
Old 05-19-2006 | 02:39 AM
TAS05CTD610's Avatar
Besides if a turbo spins one way to build boost, and it spins backwards from the exhaust (your pushing air in through the exhaust, out the air box) wouldn't it develope Vacume???
I would cover them. You never know what could get in there, rain, ect. I doubt the wind would be enough to move it bad enough to cause damage but who knows. We should find a guy that dosen't want a turbo, spin it backwards with air through the exhaust, and only have a loop oil system on it, see what happens. Since stock there is oil on the bearings (not moving) it should lubricate enough to keep it from seizing.
Old 05-19-2006 | 05:05 AM
Dieseldude4x4's Avatar
I ain't buyin this one. Towed mine all the way to Terre Haute on my GN with my sons truck and then another fellow towed it the second time. Never had a problem. I suppose it would be possible if both valves were open and enough air was moved by the venturi effect.
Quick Reply: Hauling a truck with stacks?
