Gear ratio 3.73 vs 4.10
Old 11-19-2007 | 04:42 AM
Bigdaddystroker's Avatar
I am thinking about having the stock 3.73 gears replaced with 4.10 gears.
My trailer weighs 9500 pounds loaded and I am hoping the 4.10 gearing will help the truck to pull the trailer easier. Any input on towing would be appreciated.
Old 11-19-2007 | 04:56 AM
bulabula's Avatar
stroker, fill out your sig block with the year, model of your truck and what tranny you've got in it. Over size tires?
Where you do you live, and where do you normally tow at?
Old 11-19-2007 | 06:11 AM
06 3500 dually 6 speed manual stock tires I tow everywhere
Old 11-19-2007 | 09:47 AM
Spooler's Avatar
With that G56 manual and the 3.73 gears your truck has a higher 6th than my truck does with the 48re/4.10's. You should be fine.
Old 11-19-2007 | 09:59 AM
scootertrash35's Avatar
4.10s?i pull as much as 30k and want 3.42 gears
Old 11-19-2007 | 10:49 AM
JuzPlaneKrazy's Avatar
I'm pulling 15K lbs. with 3.73's. When I get in the hills with 6% grade's I just down shift into 2nd gear and keep the rpms around 2500-2700. That put's me at about 45-48 mph with the 48re. Thats enough speed for me and the truck seems to run good in that range. The water, tranny and EGT temps are all within a good margin of safety.
When I bought the truck I thought it had 4.10's in it. So much for believeing a salesman. I guess if I pulled alot in the hills 4.10 mite make it better, but I'm dealing with it. When I'm running around town I'm sure glad I have the 3.73's
Old 11-19-2007 | 12:24 PM
FiverBob's Avatar
I think with the 6 speed manual you really don't need the 4.10 until you are towing over 12K. I went 4.10 because I am dragging about 16K. You will get better mileage with the 3.73 and be a little faster on the freeway and still be in that economical 1900 rpm range. When I am running solo, I am wanting 7th gear quite often.
Bob
Old 11-19-2007 | 01:14 PM
Vinceg99's Avatar
I tow over 20k lbs almost daily with my 3.73's and its fine and thats with the NV5600 trans so I have a lower ratio trans then you. Sure going up some hills the 4.10's would be nice but not worth the swap to me.
Old 11-19-2007 | 02:01 PM
Moose10's Avatar
Does the '06 3500 dually still have a D60/D80 ?
Old 11-19-2007 | 03:09 PM
ptgarcia's Avatar
Nope. AAM 11.5 and 9.25 axles.
design
32
06-23-2003 10:07 PM
mbw
03-05-2003 05:38 AM
Garz
02-03-2003 09:08 AM
Cutthroat
01-08-2003 09:37 AM
accordionjohn
10-07-2002 12:54 PM
Quick Reply: Gear ratio 3.73 vs 4.10
