First Post: B&W turnover ball hitch
#32
I have a B&W hitch and purchased it installed for $500. I absolutely love it because it is out of the way when it's not in use. I haven't heard any complaints about it from my friends that also have this hitch.
#33
Location: somewhere in northwestern ohio....Mansfield, Oh
I have the B+W hitch but right now the disconnect latch will not hold and it is a real pain to flip with one person . I have not looked at it ,and it could be real simple to fix just need to take the time . Another complaint would be very thin paint on whole unit I would not give the springs a long life if you do not coat them before install . If you have the plastic wheel linears you will need to do some changes to unit .
#34
B&W makes an offset ball. do u have a part #??
http://www.hitchesonline.com/turnover_acc.htm
Come to think of it, the paint on mine was a bit thin, too. The companion appears to be powder coated.
#35
it sit's ahead of the axle even on the short bed's, which is optimal for towing. Work with your trailer not against it, just slow down and take a little more time turning and backing up.
#36
The paint on mine looked like it was powder coated but I still sanded it really good and painted all of the parts that showed semi-gloss black. Looks really good and you kind of need to take a second glance to see that I have a B&W. They should offer it with black paint as an option!
Another recommendation: Re-torque all of the bolts after you have pulled with it a few times.
tobyw
07-14-2003 08:17 PM
