Firestone Air Bags and PacBrake Compressor
Old 06-19-2007, 06:47 PM
bluesurf's Avatar
sweeet!!!!
Old 06-19-2007, 10:29 PM
dadwolf2's Avatar
You have to change the normal PacBrake wiring. Normal operation/wiring has the PacBrake compressor only operate when the Cummins ECM calls for exhaust brake activation. That is, normal operation if you didn't install the optional air tank for quicker activation. If I remember correctly, it's described as an option in the PacBrake installation instructions. What you want is the compressor to come on and pressurize your air tank after the truck is running and then turn off via a pressure switch. From there you would want a pressure line going to your air bag controller and a separate line going to the PacBrake solenoid off the tank. The ECM then controls the solenoid operation to the exhaust brake instead of telling the compressor when to start running.
Old 06-22-2007, 05:42 PM
Harold-Pacbrake's Avatar
thats it.... we do a slight wiring mod add the tank a solenoid or two depending on what you want ( left & right indevid control) and your off and running
307Kenworth
03-01-2011 03:33 AM
mstep3
13
05-26-2010 11:39 PM
markp
03-12-2008 04:22 PM
SteveZ
10-24-2004 06:39 PM
03CTDCO
19
03-09-2004 07:10 PM
Quick Reply: Firestone Air Bags and PacBrake Compressor
