Factory Dodge tow mirrors 2nd gen???
I have an 02 and I thought I had seen factory Dodge Ram mirrors that would manually pull out for towing. Have you guys seen the mirrors that I'm talking about, and who makes them?
Thanks
Jim
Thanks
Jim
the ones that pull out are ****'s , they are aftermarket ( and ugly as a steam powered wrist watch if you ask me)
http://www.cipausa.com/extendable.htm
Then there are these : ( bottom of page 6)
http://www.kool-vue.com/lookup_detai...0&id=2000&pg=1
Hi Jim
Have a look at the write up I did installing the Kool-Vue's on my truck.
https://www.dieseltruckresource.com/....html?t=254174
Here is the OEM Mopar part number....note, these are NOT power mirrors as Mopar doesn't make them, just this manual version, so if you have power mirrors....you won't after you install these:
1 - 82206157
I got mine for around $325 through a local dealership.
--Sk
I've got the kool-vues and they are good, they don't shake unless I'm going over 70 into a headwind and they are power and heated. THey fit perfectly and are very effective when flipped out. You will need to get the backer plates if you do not already have the Dodge manual flip outs, the control switch and a heater buttoned A/C control panel. If your truck is an SLT or Laramie Plus its probably already got all the wiring and connectors in it.
If they are shaking, get your tires balanced!
casper_cobra
04-14-2006 11:32 AM
FRANKV469
03-07-2004 10:18 AM
