Dumb hitch question
Dumb hitch question
I never bothered to worry about this kind off stuff i just hooked up and went till i started reading this section and saw all the stuff about hitches.
I typically haul off a goose but recently i have been moving alot of equipment around off the hitch. I think it is a stock hitch not sure though doesnt have any markings but looks like all the other ones ive seen on trucks of similar make.
My question is how much can i pull off of it, if it is the factor hitch without any modification. I rescued a friends jeep, pulled a mini excavator a big chunk of the summer around the ranch, wood chippers, irrigation pumps, fuel trailers and i dont know what else. Basically all heavy things can i continue doing this safely or do i need to up the hitch some.
THanks i just dont want to be unsafe and put people and equipment at risk.
It's not like a GN or 5'er, where they back out some of the weights, it's a TOTAL of 10k (if that is what your rating is). And a max of whatever the tongue is.
Typically, receiver weight ratings are double if you use a Weight Distributing Hitch, which has a lever system on it that force some of the tongue weight back to the trailer axles. Typically, a WD hitch double the capacity of a given receiver. The receiver on your truck is a class III, if it is a factory receiver, rated at 10K max towing, and 500lbs max tongue weight. With WD the tongue weight goes up to 1000lbs, but the max towing weight only goes to 12K, I believe.
If you need to tow more with the receiver, get something like a Putnam Class V, which goes to 1200 lbs tongue and 16K towing, with a WD hitch. This receiver still uses a 2" hitch shank. If you go to the Reese Titan, the only other Class V I am aware of, it uses a 2.5" hitch shank, and you have to mess with an adapter sleeve to use lighter 2" hitches in it. The Putnam has better weight rating than the Titan anyway.
I stand corrected. Reese now has the "tow beast" receiver, which has a 17K tow rating, with WD hitch. Again, this is a 2.5" shank though.
If you do upgrade, make sure your hitch shank and ball carry the correct ratings for what you are towing. Just upgrading the receiver is not a silver bullet.
Chris
I know on the GM site there have been concerns about failure in the "stock" hitches w/ suggestions to change out to Reese or others.
The goose "carries" and the receiver "draws", so the pin dynamics are different. Rule-of-thumb transfer for receiver is around 10% of trailer & trailer cargo weight, but could increase depending on load placement and distance between truck axle and first trailer axle (longer distance = greater pin weight transfer).
I have broke the stock hitch. I pulled a skid loader on tilt trailer for about month and broke the reciever mount off where it's welded to the cross tube. I was not overloaded nor was I tongue heavy. total weight 9500lbs.
I cut it off and went with the putnam class 5 and it will hold 15,000 lbs.
Mike
Mike
Just about ALL the car hauler/equipment trailers I see are only using a standard hitch. I have yet to see one using a weight distribution hitch. A buddy hauls an 18ft equipment trailer with bobcat or tracked hoe and been in the business years only uses a standard hitch 2 inch drop. I'm not sure what his hitch weight is but it has to be more than 500lb. He tells me so long as you chain down well with ratchet boomer's you'll be ok and not get stopped.
I pulled a loaded cargo trailer from Ft. Worth to northern Washington state. It had a plate welded across the frame so I couldn't use my WD hitch. When I got to WA the hitch metal had literally tore about an inch and a half on both sides where the hitch mount bends 90degrees and bolts to the frame. That is the area to keep an eye on if you don't use a W/D and have heavy tongue weight.
Actually, the spring bars transfer weight to both the tow vehicle's axles.....and the trailer axle's......and removes weight from the tow hitch.
http://www.rv.net/forum/index.cfm/fu...d/14265335.cfm
http://www.etrailer.com/faq_weightdistribution.aspx
Hope that helps.
05-14-2010 05:06 PM
