dually tire advice
dually tire advice
is anyone hauling with 34-35s or 295/75 tires on thier dually w/ stock rims? or does anyone know where i can find 34-35" tires 11.5" wide or less???
pics and details would be much appreciated! just trying to get the RPMs down @ freeway speeds and still have good power. i thought about changing gears to maybe some 3:73s instead of these 4:10s but what do you think?
-Bryan
-Bryan
If you do go to large tires, make sure that the sidewalls do not touch. Causes wear and heat problems. Don't know what to tell you about the gear change. My truck is getting 17-18 with 4.10. 6 speed does a lot better than the automatic that I used to have. Also, my old 96 did very well on MPG until I had a plate put in it. I guess that if you want to play, get ready to pay.
You can't do much with stock rims on a '96. Your best option is to go with an aftermarket solution. On an '01 or an '02, the offset is different, and you can put 285/80's or 265/75's on the stock rims without the inside sidewalls touching. If you do that, however, you need to go with load range D's at 80 psi under load, so the sidewall doesn't sag.
Muted User
Originally posted by nauitque21
thanks.
so what do i need to fit the tires that i want? new rims or a spacer?
thanks.
I got a question about spacers for the Dually's. On mine I changed my tires to 265/r70/17 and all that i could put on mine was 1/4" spacer between the the two rims if i was going bigger on the tire looks to me I would be going to a longer stud for bigger spacers. Correct me if i'm wrong i've read were people have put 2' spacers on there truck. Did yall have to change the wheel studs out ?
Originally posted by scarecrow
yea sorry to tell ya but they are your options....on my truck with 3.55 gears and 35s at 75 mph my rpms are around 2200 give or take and my truck is a 5 speed.
and....... if i put 2" spacers on w/ 11" or so wide tires, how far are they going to stick out of the fenderwells?
Muted User
Scarecrow How are you running your 35s? do you have a spacer or rims?
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
CTD NUT
09-12-2005 04:40 PM
RobG
09-05-2003 09:13 AM
patriot pearl blue
12-09-2002 08:53 AM
