drawtite brake activator
Does anyone have a schematic for a drawtite activator. Or maybe some advice. Mine works using the lever on the controller but not when I hit the brakes. I haven't been able to find any disconnected wires but there is bound to be one somewhere that would cause this.
http://wwww.dodge-diesel.org/showthread/t-67311.html
Hope this helps
OOOPS link isnt working, try a search, there have been a few threads about this topic..
Hope this helps
Make sure you are getting power to the red wire when you apply the brakes.
Might be the Draw-Tite controller. I had one go bad on my like that.... It just went out... replaced with prodigy and no more problem since.
Power to the red wire would be my first thought though.
My $0.019
-Trey
My $0.019
-Trey
I didnt read that it was a new install or it worked good prior but I will say thru the ownership of 2 of them its locked up wheels or nada it seems. If it works manually there has to be juice exiting it to the trailer, if the brake pedal dosent activate it I would say the wire to the brake light signal may be broke or the unit has gone bad. Should be 1 10/12ga ground to battery, one 10/12 ga hot lead to a circut breaker then battery, one 12ga out to the trailer(blue) and a white?? for the brake light signal.
VICIOUS FISHER
09-18-2010 05:21 PM
StrokeThis2500
03-03-2007 08:04 PM
