Dometic Awning Help
Dometic Awning Help
I'm getting to my "to do list" of things to get fixed before our first camping trip of the year. Last year I had an issue with my awning retracting. It was like it had lost it's tension to roll back up. It is a manual retracting model. I can't find any information on Dometic's site on how to wind the spring to bring tension back. Has anyone else ever had this problem? Or know how to fix it? Thanks for any info!
Jimmy
Jimmy
Dometic
I've got a Dometic awning on my Northstar and it's a handfull to open up with two people. A customer at the dealer where I bought mine demonstrated their brand(can't remember what it was) and wow, what a breeze!
Jimmy
Jimmy
Any idea where I can find the procedure for this?? Dometic doesn't show it on there manual and you know an RV shop isn't going to give me the secret. I figure it's got to be a bit like my blinds in the cab over area, there is just a spring that you wind and it puts tension back in the winding mechanism. Any more help would be great!
Thanks,
Jimmy
Thanks,
Jimmy
Thanks,
Jimmy
Thanks,
Jimmy
I"m not sure where you can get a step by step instruction manual on how to do it. My dads owned an RV shop for 20+ years and taught me how to do it. An RV shop will tell you exactly what I just told you on how to do it.
Check the internet under A&E awnings. Dometic bought A&E. I know you can take the tube mount out of the arm and tighten the spring this way, but like the fellow said be careful. Which model of awning do you have?
when I replaced the spring and lock mechanisam on my A-E awning it HAS to be done in the retracted position. this will have the spring with the LEAST amount of tenision on it. mine said to put 8 turns of preload on the spring IIRC. it is not a hard job, just must be done VERY carefully so the spring doesnt get away from you or you WILL get hurt.
bill
bill
Winding up the awning spring.
There is a specified number of turns which we've found it best not to exceed on the A&E awnings. It seems that when the awning is fully extended the spring is pretty close to it's practical limit. If the spring is already weakened, it will likely fail by tightening more.
On the other hand, it sounds like it's no longer working right anyway....
We use a special made tool to wind the spring and it helps to have a few extra hands.
Fred
boulderrv.net
Fred
boulderrv.net
I have had (2) Carefree's & (1) A&E. Both were easy to use, easy 1 man operation. I think it is dealer time if it is not going up properly. Some things are not worth the aggervation or risk of injury.
I like the A&E a little better, seemed better made; both do the job.
Good luck!!
Good luck!!
