Dodge 1 ton 4X4 SRW Quad Cab
Is anyone using one of these as a tow vehicle. Just how high are those things?
I saw the 1 ton 2x4 SRW and it seems to sit lower than my 2X4 dually. I was hoping to get something a little higher, maybe the 1 ton 4x4 SRW can be lowered some? Any thoughts?
-Mark
-Mark
You could lower the rear some by removing the lift blocks , but the truck will sit big time nose high , there is no way to drop the front without putting in shorter coils , and the axle is plenty close to the frame as it is.
I have a 05 4X4 SRW that I tow our 5th wheel with all the time. I don't know how heavy a trailer you are going to pull but ours weighs 10,400 lbs. loaded with a pin weight right at 2k. My truck and the trailer sit level when hitched up. You can check my gallery for some pictures.
rcts
11-21-2009 11:29 AM
nvr-enuf
07-12-2009 09:55 PM
Roger Portmann
12-10-2008 09:20 AM
highgun
04-02-2008 01:05 PM
Happy Traveler
03-31-2003 04:52 PM
