Class v trailer hitch
Can you install the class v hitch with the oem in position? I have removed mine because my rear bumper has a 10" drop and couldn't use the oem hitch, so does the class V sit a little lower than the oem? I need it to drop maybe a couple more inches then oem.
Thanks in advance
Thanks in advance
Well on this link there's an illustration of the hitch in position.
http://www.thehitchstore.com/images/...-15573-INS.pdf
does that look about right? If it drops that much from oem, I can definitely use it.
I put a class 5 on my truck, it bolted up right under the factory hitch. I'd say 3-4" lower.
It solved my issues with too light of a recvr and the height with too much of a drop. I was using a 6" drop before I did this. I now use a 2" and trailer is level when hooked up.
Scotty
Scotty
