BullyDog Question
BullyDog Question
Hi
For those of you towing with the Bullydog and outlook monitor, are you able to tow at the 90hp setting and keep EGT's reasonable? Running at this high of HP will it affect the tranny?
Paul
Paul
Paul I think I've talked to you. Paul on flat ground you may not have a problem but on a hill yes your egt's would be running high but the outlook you can set up parameters to be reached like a certain egt to be reached and then begin defueling. Transmission problems are possible a new valve body deep sump pan would'nt hurt ultimately a torque convertor is the best mod for any diesel truck. Remember this as well whenever your turn up the fuel you need to turn up the air a intake and free flowing exhaust are crucial in lowering egt's
Kyle
Yes, I did speaK with you last week and I appreciate all of your help. Can you tell me a little bit about the FASS system and what the benefits would be of using this system?
Paul
Paul
LilBigd02
17
02-28-2010 09:22 AM
8mpg
05-08-2006 06:37 PM
Leadfoot
12-20-2005 12:11 PM
jayrods600
03-14-2005 08:22 PM
deezulsmoke
01-18-2005 12:15 AM
