Brake controler instalation
Old 02-03-2009 | 09:37 PM
Farmall Power's Avatar
I need to instal a brake controler on my 03 3500, is their a connection under the dash a person can tap into for the blue wire that runs to the rear plug in on the pickup?
Old 02-04-2009 | 02:51 PM
jumper's Avatar
When you buy the controller, buy the harness adapter for your truck. The truck side plug is hiding up by the parking brake cable.
Old 02-04-2009 | 10:42 PM
.boB's Avatar
If the truck was equipped with a tow package, there was a plastic bag that had a blue plug with some wires coming out. You can use that to make your own harness when you buy a controller. The instructions are in the bag. It might save you a few bux.
That plug matches the plug under the dash. On my '01 Dakota it was part of the main harness plug. On this truck, it's seperate, and just hanging there behind the parking brake mechanism, to the left of the main harness plug.
Old 02-06-2009 | 08:18 PM
LeonT's Avatar
Be sure to look EVERYWHERE for that harness before you give up. Mine was hidden in one of those small compartments that I had never used. Don't know who put it there, but at least it was in the truck and I didn't have to buy one. It's a simple setup when you have the correct wiring harness. Pretty much plug and play.
Old 02-08-2009 | 09:15 PM
Swarthy Dago's Avatar
also check the access holes up against the floorboard/firewall drivers side, look or put your finger in them, that blue wire on mine was folded over and stuffed in.
Turbo Deeezle
06-20-2004 04:13 PM
Diesel Fumes
04-04-2004 09:39 AM
alleyyooper
03-24-2004 02:02 PM
Trusty Steed
01-29-2004 03:55 AM
patrick
03-11-2003 06:55 PM
Quick Reply: Brake controler instalation
