Brake Controler
Old 07-26-2004 | 05:44 PM
OLD 93's Avatar
Brake Controler
I have new 04 dodge auto and would like to put My brake controler In my dash below The ac ***** and to the right of my 4 w auto switch. In that little cuby hole.I would like to know how do you get the front plactic cover off to drill and run the wires My controler looks like it would fit real nice In there. THANKS
Old 07-26-2004 | 07:33 PM
Tfeore's Avatar
Not to go off track here but, don't you need to get to the controller once and a while for adjustment. I thought about putting my Prodigy there but sure don't want to be fumbling for an adjustment or the manual slide and not be able to get to it when I need to.
You are right though it will look good there. Post some pics when you get done.
Old 07-26-2004 | 08:24 PM
OLD 93's Avatar
I plan on letting it stick out about two inches so I can adjust it when need be. Iwill even make a small plate to go around it so it will look clean.
Old 07-27-2004 | 05:44 AM
SuperGewl's Avatar
Let me suggest a better place to put it. try on the knee knocker above your right foot.
take a look at my photos in the gallery.
Other than that, all yo have to do is remove the screw on the bag hook, then pull the panel off, it's clipped on.
Old 07-27-2004 | 10:30 PM
OLD 93's Avatar
I put it in the cubby hole , looks good and out of the way.
CumminAtYa
07-14-2004 04:36 AM
Diesel Fumes
04-04-2004 09:39 AM
alleyyooper
03-24-2004 02:02 PM
Trusty Steed
01-29-2004 03:55 AM
patrick
03-11-2003 06:55 PM
Quick Reply: Brake Controler
