Black Streaks
I use liquid wax (turtle wax 2001), use it like a buffing compound.
Removes the black streaks and puts a coat of wax to help reduce future streaks.
Also use the liquid wax like you would for rain-x on the windows, work well.
... and thn look for the cause. When I started getting the black streaks, I climbed on the roof and found that the coating on the roof rubber needed redone. Not too hard to do, just time consuming.
PISTOL
PISTOL
I usually spray some Westley's tire bleach on it , hit with a brush and hose off.
If the trailer is going to sit for awhile try putting clip on wood clothes pins on gutter spouts to direct water from side , not perfect but it helps.
PistolWhipt brought up a good point. On that note, if the roof is full of crud, then its going to run down the side when it rains (black streaks), got to wash the roof. If your TT has rain gutters around the roof line, got to clean them out also.
if you can find a product called in awesome in the green bottle, spray it on wipe it offf it is that easy, i used on my fifth wheel could not beleive how easy it came off and did not dull the finish.
I would be careful on what you use to clean the stuff off the paint ... especially on older trailers where the paint is oxidized.
I hit the black streaks on mine with plain old Simple Green and much of the paint came too !! Of course I haven't been the best at keeping the thing waxed and trying to preserve the paint either.
Hmmm ... clothespins on the gutters to divert the water. I could have used that tip a few months ago. Thanks !!!
PISTOL
PISTOL
Ok, I just did my whole trailer and it truned out awesome. I tried everything and nothing worked well until the guy who lettered my trailer showed me. It is at advance auto and its called Purple Power I believe. This stuff is awesome. I still had to use a little elbow grease but it was nothing like what I was trying. My trailer looks brand new.
They had it in spray bottles and 1 gallon jug. I bought the gallon and put it in a spray bottle I had.
